I have an 04 Four Winns Freedom 180 43 V6 with rotted motor mounts. In this boat the motor mounts seem to be just 2"x4" 12" long on the short sides as shown in the attached pic. Below the small motor mount cavity on each side there seems to be separate chambers/cavities that appear to be sealed separately and are unlikely to have any rotted wood in them. I believe this because when I drill down through a mount hole the bit hits something that I am sure is the top fiberglass of the bottom chamber.
I am hoping to permanently repair these two mounts with composite materials without completely removing the rotted wood and without any fiberglass work and would like opinions. My plan is as follows:
1. Drill at least three large (at least 1") holes in the top surface of the mount. One between the existing bolt holes and one each a bit outside the bolt holes. (Leave bolt holes sizes as they currently are. I already drilled them out a little.)
2. Drill three 1" holes into the side near the bottom of the cavity and passing through the bottom of the vertical drilled holes.
3. Possibly drill a 1" hole into the beveled (front/rear) sides of the cavity interconnecting with the other drilled holes
4. Use drill bits, tools, vacuum, compressed air, etc... to extract as much rotted wood as possible from original mount holes and all drilled holes
5. Tape or wedge something over the side holes to seal then such as Teflon sheets, etc... to temporarily seal of the side holes
6. Pour/push some sort of epoxy material such as the West Marine product possibly with some sort of fillers added into the top holes until level
7. Allow to dry
8. Remove materials from side holes
9. Sand/clean up hole areas as needed for cosmetics
10. Drill new bolt holes
11. Cover the area with new white paint
My thoughts are that the remaining wood will eventually rot to nothing and there will be some voids in the cavity but it should be very strong with good load distribution across the area and immune to rot in the future.
Your thought and comments would be greatly appreciated.
Thanks,
Brian
7. Allow to dry
Thanks,
Brian
