Woodonglass
- Dec 29, 2009
- 25,930
Ok, I'm NOT much of a Mek-A-Nek soooo, HELP!!!! Got this motor 2 years ago, went thru the carbs, New Plugs, Impellar etc... First time out she started up ran fine for 10 mins then Heat alarm sounded. Found out when I installed lower unit did not get water tube aligned properly. fixed that. Pumps water great now. Last two trips to the lake resulted in her NOT running. Today I put her on the MUFFs before we left. Ran great for 15 mins both idle and in reverse and forward. She would rev up great and idle too.I DID have to use Starting Fluid to get her started first time. Drove 45 mins to lake, dropped her in. Wouldn't start. Shot more starting fluid, she started but... would not rev. In neutral, at idle, I was at the motor trying to rev her up with the linkage and as soon as I would attempt to rev...she would die. Motor NOT under load. Wife is getting tired of making the trip only to have her not start. I MUST get this figured out.
I've searched the forum and found some info about possible carb issues etc. but...why wil she run sooo Good on the muffs but NOT in the lake. It's NOT a load issue cuz I was NOT trying to put her in gear, just trying to get her to run in neutral. I guess I can remove the Carbs AGAIN and see if that will fix it
HELP!!! this OldDumbOkie out!!! Spent 3 years restoring this 61' Lonestar and I can't enjoy her. VERY Frustrated!!!!
