Lou C
- Nov 10, 2002
- 13,226
In fresh water regions there is no reason not to have an I/O. In salt water regions there are some basic reasons why the OB will be less trouble over time. When people say I/Os are cheaper to repower, in salt water regions it would be wise to keep these things in mind. Yes, the SBC is cheaper than an OB power head. BUT, to that you will want to add:
Closed cooling, or face the problems cast iron corrosion causes in salt water over time, ie as the engine ages, a gradual tendency to overheating due to the way cast iron corrodes. So here you are spending about $900 extra, plus installation if you can't do it yourself. If you don't buy this pull off your thermostat housing and look at it. Flaking cast iron. Look in the intake manifold. Same thing. Eventually the cooling passages get so clogged with either rust flakes or sand that its hard to keep temps under control. At least with a heat exchanger it can be cleaned out or eventually replaced if needed, saving the engine from that damage.
Replace the exhaust system every 5-7 years, (800-900 bucks parts price alone per engine) or face the risk of water in a cyl and a ruined engine.
Keep in mind in salt water the transom mounts of I/Os, esp Mercruisers, suffer due to leaks and salt water corrosion. This causes leaks around the steering arm and loosness in the hinge pins. Eventually these need major work, or replacement. For some reason this is not common on OMC Cobras or Volvo SXs. Not an issue on an outboard.
Lastly there is the safety difference. It is safer to not have the engine electrical components in the bilge. It is safer to not have to depend on a rubber bellows to keep water out of the boat. While both of these issues can be mitigated via good maintenance practices, it is what it is.
One thing I know from experience, you never see a work boat of any kind used in the water all the time with I/Os here.
When people say, well the SBC is much cheaper to replace than the OB power head, well yes that is true but its only half the story of the repairs that will come due in the salt pond....
To me this is like the choice of trailers, no one would EVER choose a painted steel trailer for a salt water boat, unless you have it launched by a marina with slings. So if you want to run an I/O in salt keep these things in mind, 5-7 years replace complete exhaust system, 15 years, engine may need complete replacement due to salt corrosion, and you best be pulling the drive every year to keep on top of that too.
