I've spent two weeks trying to research forums and troubleshoot with my Seloc manual but I'm still having an issue. I bought a 96 Bayliner 2250 SS this summer and it ran great when I picked it up. After trailering around and a tank of gas later I'm getting a pretty consistent but slight surging at just about any rpm once my speed is steady in cruise. I also get one solid hiccup when I go from idle RPM in gear to full throttle. I'm able to pull skiers but sometimes it creates slack in the rope due to the surging at cruise. The boat starts and idles perfect and doesn't run rough, the only time I crank a little extra is when I shut down for a bit when its hot and start back up.
From reading my manual and other forums I felt I should start with troubleshooting the fuel over the ignition since my surge seems so slight and I could test pretty quickly. I rented a fuel pressure tester and got it hooked up after some fitting issues and it shows 5-6 Psi at all different Rpm's with no load on it. I'm going to go out in the morning and see it under a load.
Some other things I've checked with fuel - Pulled the brand new fuel/water separator and drained it and found zero water and zero sediment so I reinstalled. I pulled the pickup tube to check the screen and it was 100% clear of debris. I took of the anti siphon valve and played with it and sprayed a lot of carb cleaner in there but everything seemed to move freely. I don't have an external tank to test on but aside from bypassing the anti siphon valve I feel I don't need to try the external tank.
I've also taking off all the plug wires and dist cap wires one at a time and put back on to make sure they were all secure.
I'm going to check fuel pressure under a load at different RPM's tomorrow if it isn't raining and will try it with the fuel cap open to make sure the vent isn't blocked.
Can anyone give me some more items to check with the fuel when I go out or some areas with the ignition to begin with this? Has anyone had this issue that I'm describing with a concrete answer?
Thanks for any help with this issue, any help would be great.
