- May 19, 2001
- 26,103
Okay this has been bugging a couple of us and since the heating season is around the corner.........I have a real technical question.
I can set the proper burn on the nozzle and measure the exhaust gases too to insure the burning is correct HOWEVER I can do that with a .80 nozzle or a 1.0 or a 1.10 to get the burn correct now how long does the fan run run in conjunction with the burner?
The fan blows the heat into the house while the jacket is hot but for how long?
Should the nozzle burn time match the fan time? Should the fan run longer?
Here is the big one - should a smaller nozzle be used? to match the fan time and create a more efficient furnace?
I have looked for web sights to explain this and have come up empty?
And help? Recommend a larger or smaller nozzle? Too much cycling will cause ash and soot which will create chemicals that are bad for the metal?
Thanks!
Thanks!
