hey all, just finishing up a rebuilt on an 89 johnson motor and tracker bass boat. i have checked, repaired or replaced every component on this motor and am just finishing up a broken woodruff key. my question is. A) how do i ckeck the timing of this motor B) ho can i set the timing at spec, or something close to specs
i looked through the forum and found this(below, highlighted gray), for which im not entirely understanding and was hoping i could get an another explanation on / ask some questions!
Thanks for your time!
NOTE: If your engine has the "Fast Start" feature", you must disconnect/eliminate that feature in order to use the following method. The "Fast Start" automatically advances the spark electronically when the engine first starts, dropping it to normal when the engine reaches a certain temperature.
The full spark advance can be adjusted without have the engine running at near full throttle as follows.
To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary).
Rig a spark tester and have the gap set to 7/16". Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4? less than what the engine calls for.
