SSTKO81
- Jun 1, 2009
- 350
Hello boys and girls. After a long out of body experience my 140 is back in the hull where it belongs. Had everything realigned and reconnected by a real live boat mechanic and it was probably the easiest $500 I ever spent. Got a new Optima battery yesterday and went to fire it up for the first time since the trial start up on the engine stand. On the stand it worked great. Ran it for about 3-4 minutes, set the timing and shut it back down (as I didn't have water running through it at the time). It sat for about 2 more months before I put it back into the boat, and another 2 months up to this point. So yesterday I started it and it would only run for maybe 10-15 seconds at a time and was accompanied by a horrendous screeching chirp (couldn't tell where it was coming from; maybe the front end?) Checked the oil and it was maybe 1/4 qt low. And actually sounded smooth for that short time other than that terrible chirp. -not a belt screech either in case you're thinking that. Has anyone else had this issue or have any thoughts, ideas, suggestions? Thanks
