Originally posted by
Tim Frank View Post
Check spark with a purpose-built tester...open gap to 7/16". Need a sharp, "snappy" blue spark.
If that is OK, move back to fuel system troubleshooting,
Check fuel pump output pressure with gauge.
I bought a tester on my way home tonight. #1 only shoots a tiny spark. Like 1/16
#2 shoots a 1/2". So I'm thinking 2 coil packs are in my future!
First, I'd only be worried about #1.... the 1/2" on #2 is more than the 7/16" that seems to be the accepted spec.
Second, as someone suggested, swap the "known-good" coil first...could must be at least $50- , and don't really fail as often as they get replaced.
Trouble shoot the circuit for number one, starting with the obvious...do a complete visual sweep, then make sure any connections are tight and corrosion-free.
