1967 Chrysler 75hp: what am I missing
NeilDaCosta
My engine was running, now won't start. When key is turned it the starter works, but the engine itself won't start. Any ideas of what to look at next?
Compression is good
Spark is good
Timed/adjusted according to Frank's tutorial. I even used the voltmeter test in the manual to test the timing.
Carbs are clean and floats are adjusted accordingly
And yes, there is gas in the tank!
Thanks.
gm280
Neil, have to tried squirting a little 50:1 fuel mixture in the carb(s)? Take a little bottle and squirt just a little into the carbs (not much) and see if it kicks over. If so, you have a fuel delivery issue to fix. If not, you need to check spark.
Also, what were the compression readings?
NeilDaCosta
Spraying fuel directly into the carbs worked, thanks. Turned over but didn't start at first. Sprayed a little more and it fired up. It stays running too. I stopped it, waited a little and it fired right back up.
Compression is right at 150 for all 3 cylinders.
gm280
Well that IS good news. Now you need to figure out why it didn't start before and fix that so if you are on the water, it doesn't repeat that problem. But glad it worked for you. :thumb:
Nordin
Check the choke butterflies, do they close fully?
These engines can be a bit cold blood to start when cool.
What start procedure do you have?
Coldstart knobe out and throttle all way forward to fast idle position.
