Rick Stephens
- Aug 13, 2013
- 6,118
No mater whose name is on them you should always take a fine flat file to both surfaces to make sure there flat
My GLMs have been perfect..... after I used a big bastard on the surfaces :^)
Salt water use? How many years do you have on them?My GLMs have been perfect..... after I used a big bastard on the surfaces :^)
Risers don't last as long as manifolds so you should replace. General rule of thumb is you replace risers twice as often as manifolds.If you replace the manifold. ....most times do you replace the risers at the same time? I am pulling both this weekend, I'm 90% sure manifolds are due just not sure about the wear on the risers. Can old risers be used with new manifolds? 86 merc 350
It's what my local Volvo dealer reccomends and it's what I see after a few years of saltwater use and its what I do. The issue is that the riser has it's insides exposed to more air than the manifolds since that manifolds are full of water after engine shutoff and the risers are not. Also, the water is always hotter by the time it reaches the risers which also accelerates corrosion.Have any links/pages/etc that indicates this rule ? Always looking for new info, thanks
Risers tend to fail before manifolds because the water is hotter by the time it reaches them, which accelerates corrosion and causes the salt to separate and stick to the walls more readily. Also, the top and aft side of the riser is exposed to both saltwater and air where the two combine, which is a perfect environment for corrosion, so you may get a few more years out of a manifold.
I am just now getting around to ordering a set....but ran into an issue, which ones should I get "wet joint" or "dry joint", one better than other?
