I have a Mariner 40HP 2 stroke. Lower unit was damaged so I bought an used one. The used one was in neutral and I can rotate prop shaft freely. So I put outboard in neutral and removed the damaged lower unit. When I put the replacement lower unit back, I managed to get drive shaft in but shift shaft was stuck. After quite a few tries and failures, I put outboard in just a little forward, then shift shaft got in. Now when I put outboard in neutral, prop shaft can still rotate both way but with some resistance clockwise and more resistance with clicking sound count clockwise; when I put outboard in forward gear, it rotates clockwise with rachet, and is locked count clockwise; when I put it in reverse gear, it is locked both way. What is the problem?
