CurrentObsession
- Aug 26, 2011
- 236
2001 4.3 EFI in 20 foot center console Alpha1 drive
Engine # 0c86926
Seems as though it is either not running on all cylinders or it is running really rich.
I have recently changed the plugs, wires and distributor cap. Plugs that I took out where the wrong ones for the engine, I was shocked to see that they were 1/2" longer than the correct direct AC MR43T that I installed. Boat seemed to run ok right after I did these things a few weeks ago, but now it takes forever to get up on plane. The back of the boat at the waterline is now dirty with soot, which was never an issue prior.
I thought at first that I may have missed getting the wires on the spark plugs properly as access is not good, but I have gone back and made sure they are on there snug as they should be, so that's not it.
It always seems to start and run well in the drive on the trailer, but terrible on the water. Today on the water, I pulled the air cleaner to observe the carb/EFI in action. First off I was surprised to see what looks like a 2 barrel carburetor, as I thought I had an EFI engine. Upon further inspection, it looks like there are injectors mounted above the butterflies on the carb that squirt fuel down onto the butterflies in idle. Seemed to me that a large amount of fuel was shooting down just to keep it idling. When I goosed the throttle in neutral I was surprised to see how very little the butterflies would open up even with a hot engine and fairly high revs. I kind of thought that it must be like a choke stuck situation, but when I got home and looked at it while not running I was able to get the butterflies to open, but I remain surprised at how much forward throttle I have to give it to see them open at all.
Any ideas on what I should be starting with?
Engine # 0c86926
