Floor is soft as wel. stuck my head in the ski bin and the hull is solid. Floor bad from the top so i believe weather is the culprit. Pictures to come when i get home.
RUN
the floor is the last thing to rot on a boat. first to rot is the stringers, then the transom, then the floor. if you had a boat that only the floor rotted and not the stringers and transom, you would be the first......EVER..... and should then buy a lottery ticket. it just doesnt happen. spend some time in the hull restoration forum
you are too emotionally attached to the boat. if you do buy it, set aside $2k for materials to replace the floor, stringers and transom.
One last thing, just to clarify in my last post I meant to say the speed and scratches are not a big deal. In the pictures it looks like the power trim is off or missing or am I just looking at the wrong place? I suspect replacing the trim would not be a big deal?
The lower unit is not cracked.
My mistake. Like I said it's hard to tell without seeing it in person. It really looks like a busted housing to me from the pics.
I woud be concerned about the deck being soft. It usually rots from the underside, but maybe not. If someone took the time to correctly replace the stringers and deck, and then let it sit out and rot then they have more spare money than me. Because that's about a $2000 repair.
Good luck with whatever you decide. If you buy it and there are any issues this is the best place to get help and advice. Although some of our responses ( Mine included) might not lead you to believe that.
And heres the one that im going to get yelled at for. This is in the ski bin looking towards the back of the boat
My $.02 cents worth, seems you seriously like the boat. And there is certainly nothing wrong with that. If you really like it and have the funds to afford it, then buy it understanding you do have some issues with rot. The under floor picture shows mold and fungus on the floor underside meaning ROT! Is that a serious problem? Maybe, maybe not. If you do understand that you can repair most anything that is rotted and/or wrong with it, then at least you go into this with that knowledge. And when you do need to address such rot issues, this is the absolute best place to get help, assistance, suggestions and guidance. You won't be do those repairs all by yourself. So let your decision be all yours. JMHO
Thank you. If i was certain that the integrity of the hull wasn't compromised by the deck rot I'd make an offer. It is a 28 year old boat. Clear coat redone and a solid motor but that means a hill of beans if it doesn't float. I can get it for 2k.
