jerryjerry05
- May 7, 2008
- 18,183
Working on my neighbors 6hp 1974Johnson
Cleanest 6 I've seen especially for the age.
The deal is I keep the motor running he supplies the boat 12ft. alum. (about the same age),and we fish his Grouper
and Flounder spots.
The owners son was working on it and it stopped pumping water.(guide tube alignment wrong)
The owner ask me to check it out.
I get it runnin and pumpin.
I get my heat gun out to check the temp.
It's runnin pretty warm, not HOT but too warm.
I pull the thermo and it's fairly corroded.
Clean it up and run it again.
Runnin cooler but the heat gun says there's a HOT spot between the cyl.
It's at 170d I think the thermo is about 140d.
The heat gun says there's a hot spot that needs attention.
I pull the head and sure enough the passages are clogged in the hot zone.
Without the heat gun I would never had found the clog.
You can see on the first pic where the clog on the left of the head is.
I spent 15$ on Amazon a few years ago and it's helped me a few times.
I figure it's saved this motor.
and Flounder spots.
