Hello all,
I have a 1970 33hp evinrude ski twin outboard that I recently acquired so I haven't had to do much maintenance with it yet. It was in storage for nearly 20 years and amazingly fired up in 5 pulls and runs great but I wasn't able to get the deck finished and try it out before winter so I went to winterize the engine and in the process of changing the gear oil I removed the upper screw which is the one that allows the fill pump to thread in and then removed the small screw near the bottom which has a magnetic rod on it. About half a cup of water came out but no oil, which until I actually put it in the water it could be as silly as the previous owner drained but never filled it. Now the problem here is that this screw on the bottom came out but WILL NOT go back in. Looking in the hole there is a metal wall blockage of some form in the eh that doesn't budge no matter what I do. There obviously was a hole it came out of but now this hole has vanished and the screw cannot go back in. I have researched and haven't found answers to this dilemma anywhere. For the time being I have found a stubby screw that fit so I could at least cap it and fill it with oil for the winter. But I have to figure out eventually why that screw won't go in. Am I missing something?
