MH Hawker
- Jul 13, 2011
- 5,516
bruce I do have a switch that's turned off when not in use, and its gets a 2 hour run once or twice week. the motor has a 4 amp charging system and I have a 15 watt solar panel to top it off... its been like this for 6 years, and I have tried several things over time. the batteries have all died with a open cell, its a 10 hp lake
i have one of the HF load testers and i am not the only one its a stream of batteries going to and from the charging shed` all summer the worst discharge is 80 % on a night fishing trip and that's once a week when its hot and no power at the slip, however the marina staff will take it out of the boat and charge it for you
its a 4 amp charger built into the motor I tried running it to charge the first year and that takes about 8 hours of run time and 9 gallons of gas sort of time consuming and it was still dead by year end and i added a battery switch
second year I added the solar panel that kept it at full charge
third year to now i just enjoy it and except it as the cost of boating on a 10 hp lake what i save on fuel and the aggravations from jet fleas and bass holes is worth it all though most of the common marine battery's i have found have a 12 mouth warranty, i am trying a AC delco this year that has a 18 mouth warranty
