Woodonglass
- Dec 29, 2009
- 25,930
Epoxy is a much better adhesive and water proofing resin. I'd just put one layer of 17oz over the whole stringer and call it good. She'll be plenty strong and sealed.
Thanks!Looks like a nice layout to me. Good work. :thumb:
Awesome! That eases my mind, I was ready to make this much harder than it needs to be! Thanks much.Epoxy is a much better adhesive and water proofing resin. I'd just put one layer of 17oz over the whole stringer and call it good. She'll be plenty strong and sealed.![]()
Check WOGs paint link again, read thru it. You picked the SE primary for aluminum boats. His link clearly lists his recommended primer, directly below the image of a spray can of the same SE peimer you posted a pix of.
I would certainly remove all that stuff and then grind everything to fresh glass. Then use plywood to make your new stingers. Most laminate two pieces of 3/4" exterior plywood together to make their new stringers. It will tons better and stronger then any standard 2 x ? wood. And if you are looking for a really good glue to laminate the plywood together, TiteBond III is a good choice. But it has to be Titebond III because it is waterproof, and not the other Titebonds. JMHO
You're finding out the trouble with epoxy.
A wise man told me to wet out the glass on the top of the stringer. Cover it in plastic, and clamp it.
