sutor623
- May 23, 2011
- 4,089
Hey guys, been working on a new to me Merc 60 hp (45 Jet) serial OG211795. It is a 3 cylinder, pretty sure 49 cu in.
Here is the issue. The motor is a bit hard starting, and will run on the muffs down to a slow idle. To the trained ear, it sounds like it is (intermittently) not firing on all three cylinders. It is erratic when you first start it at a high idle, then will settle down when you back off the throttle. In the water it will not idle down and will just cut off when you back off throttle. (Keep in mind this is a jet and it always has a load on the motor when in the water.)
Compression is 110 psi across the board. Got spark on all three cylinders. Indexed the flywheel and all cylinders are firing in the proper order.
I did the drop cylinder test and it is not reacting to cylinder 2, so that is the cylinder I believe we are having issues with. I swapped the ignition coil and no change. I am running fresh wires to all 3 cylinders.
Trigger checks out good, with proper firing order, good resistance numbers, no short to ground, and good cranking DVA. Stator has two wires, one red and one blue. The red wire has proper resistance and cranking DVA. The blue wire, for some reason has proper DVA, but when I check the resistance the number goes to 1500ohms and then just drops back off to 1. The circuit is not reading open. This seems strange, no?
Other odd issue that I noticed, is when I checked DVA of the switchbox (connected to the ignition coils like suggested in the CDI guide) is supposed to be 150V going to 300-400V (DVA) and the readings I am getting are erratic and all across the board (spiking up to 1500V)
Guy I bought the motor from (a dealer) claims to have rebuilt the carburetors but I am not sure if he actually did. Not that he is a liar, but I have heard he is not the most thorough of guys..............
With my experience with electrical systems it would seem to me that the switchbox is being erratic (which wouldnt surprise me as it is typically the first ignition part to fail on these motors.)
