GMTK
- May 27, 2016
- 174
2004 Volvo 4.3L GXI-E on a 2004 Hurricane SD187
Engine has 106 hours on it
Took the boat out today, leaving the dock the temp hit 200 and I knew we had issues. Turned back toward the ramp (1 mile) and hit 225 so I shut it down. Got a tow to the ramp and let it cool. Started it to put it back on the trailer. Engine did NOT sound normal. High pitched squeaking that was not normal.
Pulled off the hose from the water to the impeller - had HOT water in it.
Pulled off the hose from the impeller to the engine - had HOT water in it
The rest of the story - I put a new impeller in this morning. This was my first time doing this. Used an OEM impeller and it matched the one I pulled out. Followed the instructions to a T and made sure I put the hoses on the right spots and made sure everything was tight. One thing I did notice, when I pulled the housing off to start, there was no O-ring. I installed the o-ring that came with the kit. Started boat in the driveway using the fresh water inlet and a hose and it ran fine for 10 minutes.
Then took it to the lake and over heated. Going to pull the impeller off and look for damage.
What else do I need to look for to diagnose? Will check the oil dipstick. Boat was not winterized because we go out about once a month and it doesn't freeze in South Texas where we live.
Any help is appreciated.
