dolluper
- Jul 19, 2004
- 3,906
In the comes a 2012 Chevy Impala abs traction control stabilatrac control and brake assist warning lights on.. only happens when car comes to a stop at lights or stop signs....Codes are read CO 0040 ...which is loss of signal from right front speed sensor to ebcm.. Put scanner Foxwell NT 630 Pro on and watch speed sensors actions , they all pulled identical except when you applied the brake , right sensor jump to 15, 5om mph at a stop ...wiring or a sensor eh...So checks ohm sensor at wheel 1050 ohms within specs Ac scale spin wheel did not increase over 100 millavolt ac = bad wheel sensor ....if it did not ohm out at 1050 say less or indefinite it would be a wiring issue
