I was going through a box of parts from an engine I salvaged for spare parts. I found a black plastic tee check valve. The inlet and outlet barbs are 1/8" ID fuel line and it looks like it may have been mounted between the fuel distribution manifold and the primer solenoid inlet. The barb at right angles to the other two has 1/16" ID smooth hose like the recirc. hoses. There is a tiny broken tee in the other end of that hose, but I don't know where it is supposed to go to. I did not see this part in the hose routing diagram or the exploded view of the intake manifold. I can't post a picture right now. The part is about 13/4" including the barbs with a large arrow molded in, indicating the direction of flow.
