RinkerMane
- Mar 17, 2016
- 26
I have searched all over for an answer to this question. I am replacing the tach on my boat (1995) and the tach, which is a teleflex amgega 0-6k tach, has what looks like heat shrink covered push on connections. The wires are covered in heat shrink and look like they are just pushed onto the threaded terminals on the back of the tach. I have done a lot of electrical work on the boat regarding audio and new depth sounder but I have never replaced any gauges. I'm not sure if I should just pull these off, cut the heat shrink, or what. I'm afraid to just pull them when I can't see what's really holding them on. I can't see how they would be threaded on because the wire would have to twist. I definitely believe all the gauges and wiring are original to the boat and have never been touched. They are on there tight. Is this typical and do I just pull them off with a pair of pliers? Thanks!
