- Mar 8, 2009
- 43,229
Today, we installed a new ignition module (a copy - not the original Indmar spare part) using a factory timing shunt. Set base to 10 BTDC and advanced showed only 22. Rev'ed the boat while in water and the boat was able to accelerate and go to >30kn, however, if applying full gas, it would backfire during accleration.
So the mechanic manually adjusted the distributor to advanced 32 (base then at 20 BTDC) and the boat accelerated perfectly and >35 kn).
Will test of the boat starts tomorrow when cold.
Is it OK to have the base time set so high?
Do you recommend getting the original Indmar timing module instead?
My Opinion:
Something is not right, the GM 5.7 is a GM 5.7 and it makes no difference if Indmar, Merc or VP is using it. Base timing is should be set at 10 BTDC and the reason is so it does not burn a piston. Your only getting 10 degrees
Maybe not everyone, but I need to start over from scratch to verify some things.
What year was the original motor?
Which distributor is installed?
Which carb is installed?
This was a new reman motor, but with all the issues, has anyone check to make sure the motor was put back together correctly (timing gears)?
