87 Starcraft Mariner floor
mattsasso
reflooring 87 Starcraft Mariner-need rivet size
I am reflooring my 87 starcraft mariner and I am going to use 3/4" plywood. I am having a hard time figuring out what rivets I will need to secure the floor for 3/4: plywood. I know I want wide flange but what length do I need. A link to exactly what I need would be greatly appreciated. Thanks in advance
Watermann
Yeah 1" grip range is as long as they go and what you will need for 3/4" decking.
Watermann
someone11
Still trying to figure rivets out, the closed ends are for places like the transom or where they may be exposed to water?
Watermann
Yes exactly, closed end blinds are used for through the hull when you can't use solid rivets.
