wishiwasfishin
- Apr 13, 2017
- 3
Hello All,
I have been reading on this site and checking out all the restorations for a long time. Some amazing projects and info on here. I bought a 18 foot Starcraft open bow a couple of years ago. It was semi restored by the original owner. He put new carpet and got everything cleaned up and functioning well. Motor is a Johnson Powershifter II 85HP, runs good but is a little stubborn on initial startup.
The issue that I am having is that the boat takes on a good amount of water, and it appears that it is coming in through the strakes at the bottom of the Hull. When some water accumulates in the hull on the trailer I can see it come out of the little holes on the strakes. If the plug is in it will slowly drain out of the holes on the strakes.
I remember reading somewhere online that someone had a similar issue and they solved it by drilling holes along the strakes and filled the strakes with adhesive caulking to seal up the inside of the strakes and I guess the rivet(s) that were causing the leak.
Does anyone have any info or experience with this doing this? I know the right way to solve the issue is to tear into it and fix the leaking rivets and use some Gluvit and really seal everything up, but I am not prepared for all that right now and am looking for a quick fix for this season.
I'll add some pics when I get home.
