Nice looking SC build, coming along nicely.
Thanks for the kind words, I couldn't get this done without the generous help of the people on this forum!
No for filling the pitting I've always used Marine Tex, using a bondo spreader to skin the pitting over and then sand, prime/paint. For unwanted holes I use JB Water Weld in the 2 part stick epoxy. Counter sink drill on the inside with a bit larger than the hole to make a bevel. Take a wad of the JB press it firmly into the hole giving pressure on both sides. Once cured sand the JB down flush. It's tough stuff and would have to be beaten out with a hammer.
Floor looks good.. That's good advice watermann gave you on filling the holes..
The single center stringer is loose, and appears to have been re-riveted many times. I saw another thread where someone used parts of an old aluminum ladder to cross brace their stringer to the ribs. I found some aluminum 1/8" by 3/4" angle that I'm going to rivet in from stringer to rib to help stiffen the stringer. A good scrubbing and gluvit on the interior rivets and seams and I can start coating the plywood with 'poxy prior to installing flotation and getting the deck down.
You would think something small like a cleat would be a snap to get off. Not so with these, rusted nut and bolt, could not get a tool, grinder or saw in place to cut the bolt. Finally got out a small drill and 1/4" bit and cut down into the heads until the head popped off and bolts dropped out. Easy-peasy after all. The cleats aren"t anything special, but I want to reuse whatever I can cause I'm cheap!
Over the years there must have been much hardware mounted along the gunwales, holes everywhere. Gotta figure out how to deal with all of them, any suggestions?
Found the 2" angle aluminum Watermann suggested, starting on that this afternoon.
