Stephanefortin120
- Apr 18, 2017
- 7
Hi, just purchased an older fiberglass inboard boat. It has a 1984 mercruiser 2.5L 120. The previous owner said everything worked when it was winterized. Got home and put a battery in and as soon as I got the wires hooked up the terminals were sparking, smoking and melting the posts. I took it off right away. looked around and found that the orange wire going from the starter to alternator was very hot and also smoking at the ends. Got a new alternator thinking it was something going on in the alternator. Installed new one with the same results. I'm baffled and not sure what to do/check next.
Also the power trim doesn't work. when I press the up or down it clicks by the motor but nothing happens. sorry I'm new at this.
