chuckh0608
- Apr 28, 2017
- 2
I have a 2000 Xpress X56 with Motor Guide 56# Brute hand operated trolling motor. There are 2 separate sets of 6 gauge wires, each set running to its own battery. The trolling motor housing has a 12/24 volt toggle switch on the bottom. It has always worked fine. The boat has sat idle for about 2 years. I recently got 2 new batteries. Now however the trolling motor only works on 12 volt, nothing happens when I flip the switch to 24 volts. I switched the wires between batteries and the same. I checked current with a test light to make sure it was passing past the 40 amp breaker and both had current. I thought it was the trolling motor but we took it off my boat and changed with another boat. My motor works fine on the other boat. And the other motor does the same on mine not turning on 24 volt. Anyone have any ideas or suggestions as to what might be going on?? Not sure if there are other fuses etc somewhere down the line.
