My 1989 5.0l Mercruiser with the Thunderbolt ignition is having starting issues when hot. I replaced the starter, battery, plugs, cap, rotor, and carburetor. The motor runs at about 200 degrees at 3000RPM. it will start immediately when cold or if I start it right after shutdown, but if I let it sit (I. E. Swim break) for 30 minutes, it just turns over but will not fire. I've seen lots of posts saying possibly vapor lock. I'm wondering if it could also be a failing ignition module?
