Hi there,
I just bought a boat with a volvo penta AQ170 motor which runs very good. Everything works as supposed and the engine stayed cool.
On my second boat trip there was a very shallow canal which caused a plastic bag and a tshirt wrapped around my prop. After removing it I noticed my engine temperature was in red which scared the crap out of me.
I waited for the engine to cool down and went back home (which took a few engine pauses to reach). The next day I tried the engine again in idle and the temperature goes towards 70% in a matter of minutes (idle).
The first thing I checked is the water pump impeller which looked great.
http://imgur.com/RMU371X
The above is how it looked. I took it out and put it back with some new grease.
Next thing I did is disconnecting the water pump intake from my sterndrive and connected a hose with a bucket of water on it to test suction. Well, the bucket got sucked empty so my guess is the suction is fine.
Next thing I did is check the thermostat by putting it in a pan of boiling water. The thermostat opened and closed just fine...
Now comes the weird part. I let the engine run for few minutes till about 60% on the temperature meter. Then, I turn it off, wait for 2 seconds and turn it back on. 2 seconds after restart I notice my temperature meter going down to about 30% in around 10 seconds. After that it starts to climb back up slowly again. I thought this was very weird...
I hope someone can give me some tips and help me out!
Cheers,
R0yall
PS. Aside from cooling. The motor still runs great..
Cheers,
R0yall
