Hi
I don't have a seacock on the water inlet from the sterndrive. If I try to drain the system while in the water is the system actually low enough to let the sea water in? Since the highest point is when it goes into the heat exchanger which is above the water line.
I know it's clearly not recommended in the manual with a sinking risk
