2008 inboard spedo problem
Etzler
Have a 2008 Ski Centurion. Took it out today and the spedo was reading crazy high. It would jump around at low speed and peg out at 60 when faster than idle. (Perfect pass read correctly). How does the electronic gauge get its speed information? Is there a setting on the gauge itself for calibration? History on the boat. It had sunk and I replaces the instruments and most other electrical items.
If its electronic, it is GPS. If its mechanical, its a pitot tube
Silvertip
Directly to the gauge. Not a traditional pitot style gauge.
Jarcher3
is your paddle wheel clean? is it in good shape? possibly a current issue or a gauge issue..
i completely forgot about the very short-lived paddle wheel gauges.
Jarcher3
^thats why i cant find spedos for paddle wheels!!!
Etzler
Does the perfect psss get its info from the paddle wheel? It reads correct. The gauge does have a six position switch on the back, and I've matched it to the one it replaced. Maybe I will just work my way through the settings.
Etzler
Problem fixed. New spedo has a very small 6 position dial on the back. That dial is the key. Had to try several different settings till I got the correct one. Note. Setting didn't match original spedo.
