Hello, new here and hope this helps me. I have an 18ft angler 180 and repowered it myself from a 90hp to a 150hp. The motor is 100 lbs heavier than my old 90hp and now it wont stop porpoising. I've filled the internal tank and moved all gear to the front besides the battery and oil tank.it get out of the hole great but no matter where I set the trim she still bounces. I've tried lowering the motor to the lowest on the transom and still the same result. Do I need a hydro foil? Trim tabs? Different prop? The prop I am running is a merc 14.5 ? 19p. Any help would be apreciated. Thanks
