So now that I'm back to work on the boat, I'm tackling several things at once... first, I reinstalled the trim pump, the starting and deep cycle batteries, and laying out the new wiring from the batteries to all the accessories (amp, fuse block, bilge pump, etc...)
I also got the trim rams rebuilt and reinstalled along with the outdrive.
That being said, I ran into a bit of a hiccup on getting the engine aligned... I thought I had it pretty good but the drive kinda jammed up while putting it on... so ita just sitting there half on until I finish up the wiring so I can use the trim rams to push it back off...
I also started on reupholstering and took out about a billion staples on the first side panel then ran into a hiccup and it looks like they kinda interweaves foam and fabric and there is no way to remove it without ruining some of the foam... I think I'm just going to redo the plywood and foam for the side panels... it was in decent shape but there was some soft spots on the very edge.
That's where I'm at... lots of stuff left to do tho
