Ding,ding, ding.....
Per CDI documentation. They make regulated and unregulated models. Don't think your AGM would like the 16 volt output allowed by the spec sheet.
The regulated version spec is 12.5 to 14.2 volts. It's clearly noted in the documentation that these voltages don't met the charging requirements of gel and AGM batteries.
Gel and AGM "batteries will see a gradual degradation in performance over time" from inadaquent charging. They go on to say AGM and Gel batteries should fully charged with an approved charger before use with their regulators.
Maybe my commercial background but it's quite obvious to me at least, that the warranty disclaimer is to cover AGM and gel battery damage claims.
actually the wording comes across not as a warning for the battery, rather a warning to the regulator being damaged by having an AGM....
I think a few above kind of explained it.
Not ALL of their regulators have this requirement, just THIS one for 225hp looper of the 80s(I'm sure a few more).
and another poster stated that they make exact replacement of the original equipment, thus don't assume any upgrades....bummer.
definitely been seeing voltage spikes in the 16v range whilst running....so that's pretty high...probably not great for the battery, but haven't seen any issues in that regard, but I don't want to risk damage to the regulator....sooooo....going to follow instructions and replace the AGMs with typical batteries and sell the AGMs...
from what I read on a battery maker's website, not a lot of outboards recommend the AGM...their site had ONLY the honda outboards with AGMs..
sad...the AGMs I have, been there for years and perfect, the previous non-maintenance-free flooded batteries lasted maybe 1 or 2 years....UGHHHHHHH
