I have a Volvo Penta SX-M 1.79 and I believe I have a U-joint going bad. I notice a faint knocking noise when the motor is trimmed all the way up and when the steering is turned all the way to port. I bought the boat last year (my first boat) and didn't now that I shouldn't be starting the engine trimmed up until researching this noise. Since I purchased it, I have always started the engine trimmed up for a couple minutes each launch.
I feel confident that I can replace the U-joints following the manual but have a couple of questions.
1. If I caused the issue starting the engine with the outdrive trimmed up will the Gimble bearing need to be replaced too (the gimble bearing and u-joint bellow was replace 3 years ago)?
2. If I remove the outdrive and the everything appears to be ok with the u-joints and gimble bearing is there anything I need to replace like O-rings, gaskets, etc. before reinstalling the outdrive (I've purchased the alignment tool already).
3. If the U-Joint is bad...is this all the parts needed to repair it? https://www.amazon.com/Sierra-Inter...e=UTF8&qid=1495989366&sr=8-1&keywords=3850812
