I have a 4.3 mercruiser, carbrueted with thunderbolt 5 ignition. This issue started the first time using the boat this season.
I took the boat out on the lake and it seemed to be running good while cruising around at 3k rpm in cold water. The engine temp went to 160 before t-stat opening then dropped to 120-130 and stayed there. Then after a few minutes driving at 6 mph motor stalled. Got it going and made it to the dock. A mechanic I knew happened to be at the dock and he quickly looked at the boat and gunned the engine several times and it didn't stall. He left then I gunned it and it hesitated and carb backfired. The doesn't happen every time but maybe every three times. I added sea form and sprayed carb cleaner in the carb. Removed the gas strainer on carb it was clean and sprayed carb cleaner in carb though gas line.
At the end of season I change oil and filter, oil and water separator, plugs, replace 160 thermostat with 140.
Any ideas, I'm leaning to a carb rebuild but want to run it on the lake a couple of more times to get the sea form through the carb.The boat idles smoothly at 850rpm's and back fire doesn't happen every time.
