tylerdale101
- Jun 8, 2017
- 30
Hello, my name is Tyler, I am sixteen years old and this is my first boat project. I have a Cheetah 170v with a 1983 Mercruiser 140 with a MR Drive. Previous owner left the boat forgotten in trailer position, it leak water out of the rear core plug. I pulled the engine replace core plug, bellows, lower shift cable, trim limit and sending units, and impeller. I have put everything back together and the trim cylinders only go down with the down switch pressed and someone standing on the back. Up switch and trailer work properly and quickly. I disconnected hydraulic lines at the pump and ran pump in both directions, up pumps oil, down pumps absolutely no oil at all. I don't know how to identify my pump, it has a round metal oil reservoir with a diameter the same as the pump, it has the duel solenoid set up. What are the possible causes? What pump do I have? Your help is greatly appreciated!
