I recently purchased a 2000 Searay 210 with a Merc 5.0. Before purchasing I went for a 45 minute ride, looked it all over and all was good. the Family and I had it out for almost 8 ours starting and stopping multiple times with no issue, It fired on a dime. I took it home, hooked up the muffs once again no issues firing and let it run for 30 minutes to flush (brackish water) then parked it. A couple days later we took it to the marina and it will turn, the fuel pump primes, All looks well but it wont fire. I did some troubleshooting and the distributor cap looks almost new with no corrosion, the rotor turns, the coil is getting 12 volts and tested out fine compared to another regarding resistance. I am getting fuel just no spark from the wires or the coil plug. I am at a loss.
