rsmith0801
- Jun 24, 2017
- 6
I upgraded my manifolds to EMI thunder exhaust on my Baja 202 Islander. I have the Corsa Quick and Quiet thru hull with the "Y" that sends some thru the drive. After I installed the EMI manifolds I have plenty of water flowing out the drive but have none coming out the exhaust tips as I did before. I am thinking I made need to do some modifications and possibly change the rubber boot where the riser goes into the "Y". With the new exhaust the riser are stainless high flow and the boot may be restricting some of the water from passing the "Y' and going out the tip. The boot has a lip on it in the middle that I believe meets right where the water comes out of the riser. Anyone have any insight or had this problem? Is water not coming out the tips a real problem? I feel the tips were getting hotter than they should and I am concerned that when I take it out and really run it, they will get hotter. Help please?
