Dingledorf
- Jun 27, 2017
- 4
1984 evinrude 3cyl 70hp
Replaced old solenoid because it was stuck closed. Ever since I installed the new one it only clicks once with key... I've replaced several times thinking I kept getting bad solenoids.
I've checked cables and ends. Corrosion. Replaced what I thought might be damaged wires. Checked neutral switch and key switch. Used volt meter and checked battery, power at solenoid. Everything seems fine other then no power coming out to the starter. I did use another starter off another outboard to see if maybe my starter was bad (too much resistance) and yet again nothing but a click. I can jump the solenoid and starter engages.
Please help!!
Please help!!
