I recently aquired a 16ft 1977 Sea Sprite with a 1972 Johnson 125 horse outboard on it on a trade for a vintage 5th wheel my wife and I never used the. I know that the 125 is far too much horsepower for the boat which should be 80 horse max so I will never run it at full capacity as I know too large of an engine could bust the transom right off and ideally would love to trade down for someone who wants more horsepower!
It is an old motor and not without it's issues upon my initial inspection in the driveway everything looked to be in decent shape new plugs and wires as well as some upgrades on the wiring dual batteries and selector switch he had the carbs cleaned. But he told me it was "cold blooded" and had always been a bit of a pain to start but once it warmed up it ran great he told me the trick to getting it going which works good however once it gets going. The throttle works intermittently there are times where it will get up and go and other times it will big out and stall I went today to check the points and found that all 4 plugs were loose I torqued them down cleaned the fuel filter out and inspected the engine a bit closer and found a few other simple things anyways I am hoping this will help quite a bit... But wondering of loose plugs could cause the engine to bog down and stall when accelerating what else should I check before taking it out on the water
I appologize if I sound dumb I am familiar with smal engines and cars but not outboards this is my first boat and would love to get this engine running smooth so I can out it up for trade for a more adequate size for the boat
Mike
Mike
