Augoose
- Mar 21, 2010
- 1,238
All,
I consider myself fairly experienced when it comes to computers but this problem has me stumped. I've got a old HP Pavilion A1250n tower which I have running Win XP Pro to serve as a Security Camera server. Long story short, about two weeks ago I noticed it had shut down on its own and both the CPU heat sink fan and the rear cooling fan were running on high. I assumed my motherboard had failed so I ordered a new one. After replacing it, I got the same symptoms, so I then assumed that my CPU failed. I replaced that - same symptoms. Won't boot to bios, no post- just spinning fans.
I replaced/swapped ram - no change. I removed PCI components and really everything but the CPU, power supply and hard drive - same symptoms.
The power supply is putting out various voltages on various pins - I didn't pull the spec sheet to see if all voltages were within specs and instead assumed that if I'm getting various voltages (3, 11, 5, etc) that the power supply is likely good.
What am I missing?
What am I missing?
