masonh
- Nov 22, 2016
- 11
I'm working on the outdrive for a 1976 StarCraft Islander. Engine is 165HP, outdrive is Pre Alpha Mercruiser - number from inside of gear housing is 1623-5412.
Does anyone know the machine tolerance for the surface where the drive shaft goes into the upper unit? The surface marked as .879 in looks a little worn and there was some water in the upper gear case so I am chasing out possibilities. This looks like the surface where the shaft goes through part #10 (SEAL, Oil, DRIVE SHAFT HOUSING - LOWER). I want to make sure I have checked this close before putting it back together.
Thank you!
Thank you!
