lonewolf41
- Jun 28, 2013
- 173
SX-M1 drive (3869337 ser # 4202165914). Just getting ready to try out the new boat but once I shift into gear, I can't get it back in gear without turning the prop by hand. I just refilled the drive after replacing the shift piston seal. I noticed when doing the prop rotation during the pressure and vacuum test that the prop shaft would turn about 180 degrees and then get "stuck". I could turn it back 180 degrees and it would get "stuck" the other way. When the prop was stuck, I could not shift the drive into or out of gear. As long as the prop rotation was between the "stuck" positions, it shifts in and out like butter. When it was in gear, you could turn the drive/input shaft and the prop would turn fine in both forward and reverse. Now that I have it installed, it behaves the same way.
If the prop is moving freely, I can put it in and out of gear just fine. If the prop is stopped to where it is "stuck", I can't get it to shift either way. I can go to the back, turn the prop to where it turns freely and I can move the shifter freely.
Not sure what is causing it or what to do or check.
TIA for any help,
-Keith
TIA for any help,
-Keith
