I have a 1980 searay with a mercruiser 350 c.i. 260 h.p. engine. It will not start due to lack of spark at the plugs. I have traced the no power back to the coil. There is 9.5 to 10.5 volts across the positive and negative terminals of the coil depending on battery strength. There is absolutely no voltage coming from the coil to the distributer. The coil was replaced with a new one and the same problem still exists.
