I have a 2003 Regal Comodore 2860 wuth twin mercruisers. The starboard engine will not start. When I turn the key, nothing happens. No gauge movement, nothing. The port side engine works fine.
1-I checked the starting switch (is fine/I switched it with the port side)
2-I have 12 volts at the main /red cable that feeds the starter switch. But wen I turn the switch, it drops to 1 v (1 v at the red/main feed and 1 volt on the purple cable that feeds the gauges)
I checked the red fuse breaker in the engine..its fine.
Please help.
Tks!
Please help.
Tks!
