Hello boating gurus! I'll try to keep this brief, and sorry if my questions aren't worded right... please try to read between the lines. THX
I transplanted from a 4.3L carb I/O to a 5.7L TBI (donor boat was '97 mastercraft inboard). Had to extend motor mount bunks, but most everything else bolted up. Fuel system had to be reconfigured & replumbed at the front, as the previous pump and filters were located at the engine's rear when in the mastercraft.
Question 1 - 5.7 starts and idles fine... But I need to set the base ignition timing. Is there anyway to do this without attaching a scan tool. I've read that you can ground the purple/white wire and then adjust... but with the electronics and ECM I am hesitant to ground any electrical wiring unless it is confirmed by someone with more knowledge. Next question... where is the purple/white wire going to/coming from... so I can easily locate it.
Question #2 - I haven't had the boat in the water yet. And realize I may have to include the shift interrupt into the system, so I can shift under load. BUT, the donor boat didn't have the shift interrupt system installed (I assume due to it being an Inboard only). I do have the components, but the EFI coil has a plug in connection... not screw terminals. SO... It seems the solution is to simply tap into the coil wire harness to make the grounding connection thru the interrupt switch system? Can anyone make suggestions on how to identify or test polarity of the coil since I don't believe the plug-in connection or coil is marked with polarity. And then, which coil polarity side should be grounded thru the interrupt system?
Please answer any or all... And thanks in advance for your input!
