soggypants
- Jul 25, 2017
- 4
Hello all,
Looking for a recommendation please from the forum:
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]1) Performance issue you are trying to correct.
Cavitation when turning tight or even medium turn when tubing / water skiining. Would like better handling. Honestly, hole shot is fine, top speed is fine for size lakes I am on. [/FONT][/COLOR]
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Aluminum - [/FONT][/COLOR]Solas 3511‑150‑15 15
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]3) Current prop diameter and pitch (required).
15", 15"[/FONT][/COLOR]
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]4) Wide open throttle RPM and speed with an average load (very helpful)
5400 RPM, 36.8MPH (using GPS)[/FONT][/COLOR]
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]5) Engine/drive make, model, year, and HP[/FONT][/COLOR]
2006 Yamaha 150TXR 2-Stroke Series (x1)
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]6) Boat make model, year, length and weight[/FONT][/COLOR]
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]2006 Nautic Star Boats[/FONT][/COLOR]
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]210DC SPORT DECK/DB[/FONT][/COLOR]
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]21'[/FONT][/COLOR]
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]8'6" beam[/FONT][/COLOR]
[COLOR=rgba(0, 0, 0, 0.87)][FONT="]2650 lbs dry (no motor)[/FONT][/COLOR]
60 gallon gas tank
Thanks in advance - specifically, should I get a 4 blade or three? I assum stainless steel is better in every way except cost. There is a dizzying array of manufacturers. Is there really a difference between brands?
Thanks
Michael
60 gallon gas tank
Thanks
Michael
