I believe it's a 1971 chrysler 9.9. Model number 92HB Serial number 5189. I bought it 2 days ago. It started up for the owner on the second pull, ran good, no problems. I take it to the water the next day and nothing, won't fire. Can't find the choke on the motor. At the time I had just filled the gas tank up and added 50:1 ratio 2 cycle oil with it. Got home and checked the gas lines and gas is getting to the carb. Checked the spark plugs and the were blackened so I just put new ones in. I saw on another forum that a guy was having the same problem and someone told him if the motor turns over much easier with the plugs out to shoot a little oil in, spin it over several times, install the plugs and see what happens and they guy said he did it and the motor started right up. So I tried this and now the motor does not want to turn over when I pull start it
